99 cbr f4 fuel pump
Old Yesterday | 02:39 PM
Originally Posted by Rochellecbrf4
Yes that particular part I believe is my problem
Agreed. I just wanted to make sure we were talking about the same thing.
Old Yesterday | 02:52 PM
Rochellecbrf4's Avatar
I believe it’s fixed now my issue is it wants to bog out and cut off when I try to creep forward unless I get it up to atleast 4k rpms and bogs when rolling and try to burp the throttle
Old Yesterday | 03:00 PM
If you fully disassembled the carbs, you will need to sync them. What you are describing could be a symptom of that.
Old Yesterday | 03:01 PM
I have an open circuit in my air valve solenoid wiring loom could that be the roseon for that? Aside from carbs likely needing to be synced
Old Yesterday | 03:04 PM
It could.
Old Yesterday | 03:05 PM
What would be a likely reason for the open circuit? Could it be the actual solenoid is bad causing it to show open circuit in the test?
Old Yesterday | 06:23 PM
An open circuit is usually called by a bad connector or wire. I don't think the solenoid being bad would cause an open. But I've never had to troubleshoot that condition so I can't say with certainty.
Old Yesterday | 06:25 PM
I think I’ll just do the low speed ram air delete and get rid of the air valve
welloe
05-25-2021 04:15 PM
Xavierf4
08-12-2018 03:05 PM
Daniel Mollywhop Ely
05-15-2014 12:22 AM
loyerj2
08-03-2010 07:14 PM
dreamls1
05-04-2008 08:56 PM
Quick Reply: 99 cbr f4 fuel pump
