98 CBR600F3 wont start >FIXED<
I just bought my bike, and the orginal owner started it up fine and drove it to a place where we could load it while I drove my truck. This is my first bike and I think I may have ran the battery out while trying to get it started, because it no longer starts. Let me tell you what happened and see what you all think.
I put the bike in neutral and fliped the engine shut off switch, turned the choke to max and pressed the ignition, it started right up. Then when I pulled up to the stop sign I accidently let the clutch out and killed the bike in first gear. After that I attempted start it in first gear but it never fired and thats were im stuck. Any ideas?
UPDATED:
FIXED THANK YOU ALL!
UPDATED:
Not sure if its your problem, as I'm pretty new to bikes also, but when I first got my bike, I tried starting it like a carbed car. I pumped the throttle a couple times, then turned it over. The bike started for me once, then didn't start again. I flooded it and fouled the plugs. Put new plugs in it, and it fired up after half a turn. There's some very knowledgeable people on this board, so hopefully you'll get some more input ![Big Grin](https://cbrforum.com/forum/images/smilies/biggrin.gif)
Hope you figure it out.
That sounds exactly like what happened to me. Once I got it started I pulled the throttle a couple of times. Before I took off then when i came to a stop it died and didnt restart. Now my question is where are the spark plugs located... like I said Im new to bikes but im a Mech Engineering Major so I figured I could get some different sort of practice doing my own work.
I took out all the rubber stoppies to air out the plug, as said somewhere... that what to do if they are flooded right? But before I did this I removed one of the rubber stoppies to see if i could see the spark plug and when I replaced it the ignition stopped cranking all together instead of the weak cranks of a low battery. Any idea why that is?
I posted this in another thread, but this is how I changed my plugs. You'll probably need to remove the plugs themselves as they will be fouled (coated), and if your gonna take them out, then just put new ones in. Also, I'm a ME major at University of Missouri- Rolla, were do you go and what year?
I got my plugs at o-reilly's for around $6 a peice. I'm pretty sure they are 5/8. I took off my tank, and took off the airbox. Unplug the wires from the coil, and pull the coil off the plug. I used a deep 5/8 socket along with a 3inch and 1inch extension (a 6 inch was too long for me). Use the wrech to break the plug loose, then use the extenstions to unscrew it. I used a long magnet to pull the old plug out, then just drop a new (gapped) plug in, and repeat. You'll have to fish the coil and socket/extension in and out, but its manageable, I've only had my bike for a few weeks and already had all four plugs out twice, hehe. Once to clean them, cause the bike wouldn't start and once to put new ones in. I can pull it all of in 30-40 minutes not hurrying anything.
Hope this helps!
Logan
Hope this helps!
Logan
Just pulling the rubber off with do nothing, a motor will eventually dry up, but if your plugs are fouled, they won't get any better. If you don't have new plugs, take the old ones out and wire brush them real good. I would recommend getting new plugs anyways ... even if thats not your problem, it will be avoided in the future.
