954rr starting issues
Hi, I posted this 2wks ago in the 954rr section but the forum seems dead there, if anyone could help me out with this issue I'd be grateful.
I noticed my bike was getting hard to start, from when I leave the house to get petrol for instance. Initially it'll start from cold no problem but if I switch off and then try to re-start it'll chug as if the battery is dying. So it seems it'lll start from cold no problem but then will immediately play up if switched off and re-started. Battery checked out 100%, I ran diagnostic and it threw two fault codes: cam pulse generator IAT sensor Anyone have any idea which is most likely to have caused this fault? It has a PC111 fitted and a Remus pipe, always smelt rich to me from when I bought it but even more so now. From what I know 954's do run a tad rich anyhow. Today it wouldn't start at all straight after my commute home, cranked but wouldn't fire, I left it 30mins and it started. Another note to make, I turned down the PC to mid-way, it had previously been set two bars towards rich. I changed the plugs around 3mths ago, they looked normal as far as used plugs are supposed to look, also changed the air filter, there once absolute minimal touch of oil in the air box as per what is described as normal. |
Start with investigating those two codes.
Originally Posted by 74demon
(Post 1299785)
Now my ignition is blowing the 10amp fuse! Is a loose wire at the fuel pump the likely cause of all this?
Is this forum usually so dead?! |
Hi Dec111, hope this helps a little with the IAT, look at page 3-18 ,code 9 then go on to page 5-22, a problem with the voltage at sensor, could be a loose wire at the ECM.
https://www.dropbox.com/s/qd036m11p7...20954.pdf?dl=1 your looking at the Green/Orange and Grey/Blue at the ECM |
Originally Posted by CaBaRet
(Post 1299834)
https://www.dropbox.com/s/qd036m11p7...20954.pdf?dl=1 your looking at the Green/Orange and Grey/Blue at the ECM Need the flaming thing running by Fri! |
You could bet your life that it's a loose/bad connector/ earth that's causing your problem, bout the only thing you can do at present is go thro the connectors testing for loose wires /bad earths, also check out the cam pulse gen, have you got a manual.
(Post 1299836)
(Post 1299836)
Hi , take it you live in the UK with having HISS, yes go for the earths affecting ignition first, check that the wires are correct at the ignition, IAT is the problem with the restart, could be sensor or just loose wire.
| All times are GMT -5. The time now is 06:16 AM. |
