-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   929 tachometer not working (https://cbrforum.com/forum/general-tech-9/929-tachometer-not-working-2578/)
fratzke7 Jun 27, 2005 09:48 PM
I have tried 2 different gauges so I know it is not the gauges, can anyone tell me what else I can check, I have checked the fuses. Is there some kind of sending unit or wires that I can check Please I need to fix this the bike is sold!!
rob245360 Sep 10, 2020 08:59 AM
Tacho not working
Take negative lead of battery then replace needle should rise and fall to zero if not cured.
check for current at ECM no current wiring if current may be ECM unit
The fact that the first test indicates the needle moving would negate I think any wiring probs
at the tacho end. Hope this helps I had the same problem.
74demon Sep 10, 2020 09:13 AM
2005.... He sold the bike 15 years ago.
