2009 cbr 600rr Strange running issues.
I have an extremely clean and bone stock 09 limited edition cbr (blue and white) that runs excellent for a days worth of riding, and will ride in hot, cold or anywhere. Runs excellent up until after a day of riding, it will shut off at a light. Trying to start it back up proves difficult until you prime it two times with the killswitch with gas. It will fire up then die again later, and the more you try to keep it running, the worse it runs. It will fire up and idle at 1500, then die to 1000, and when you give it gas it boggs up or will rapidly go up, or rapidly decrease. Riding it one day to get home, it was drving at 7000 rpm then rapidly went to 5000, then back to 7000 multiple times, felt horrible.
i parked it for two hours then rode again with no issues, and rode it for another 4 hours until putting it away. Its done this exact thing before again and i have no clue whats going on or what to fix
2009 cbr 600rr limited edition. stock exhaust and stock everything
Hi, looks like your losing the primary and secondary injectors at the same time which could be an electrical connection fault ,or even a fuel pump fault, as I don't think its the injectors themselves have a look first at the fuel pump and connections especially the Green wire if its loose into the connector at the fuel pump
Hi if its not the connection, could be filter blocked in side, are there any faults showing, Check here for your manual
StephyGee.com
StephyGee.com
