2001 929 wont start help!
Old Feb 15, 2007 | 01:24 AM
johnnyjjohnnyj's Avatar
Default 2001 929 wont start help!
I had to leave town for about a year and didnt start my bike at all. When I got home I went to start the bike, all the electronics work when I turn the key to "on" position...but will not start...does this have anything to do with fuel injectors? help!!
Old Feb 15, 2007 | 01:34 AM
KingMushroom's Avatar
Default RE: 2001 929 wont start help!
You'll need to supply more info then that. Is it turning over? Did you store it with a dry tank? Is there FRESH fuel in it? Is the petcock open? Do you have spark? Are all your cables seated?
Old Feb 15, 2007 | 01:46 AM
My bad. When I stored the bike it had a full tank of gas...when I got back first thing i did was take the old gas out..and put new gas in..even be4 i started it. and no it wont turn over at all. I just got back I havent had a chance to check anything out yet, wish I could give more info. Thanks
Old Feb 15, 2007 | 01:54 AM
Ok, that's at least a start. Check your fuel screen first off. You'll have to empty the tank again, but make sure the screen is clear and not gummed up. If it is, use some gas/solvent and an old tooth brush and you can clean it out. (the screen is inside the tank attached to the petcock assembly).
It's most likely a gumming/varnishing problem that you should be able to solve fairly easily.
Check your plugs/wire brush them. Again, make sure the petcock is open, and give it a couple throttle rolls inbetween each firing.
If you have trouble past that, let me know and I'll see how much I can walk through everything I can with you.
Old Feb 15, 2007 | 03:32 AM
jeh2324's Avatar
Wait...if it's not turning over, I'd start witha chargedbattery....
C Jacob W
Jul 29, 2013 11:03 AM
dgk600f4i
May 7, 2011 05:17 PM
roho
Jan 22, 2011 05:28 PM
cowboyhill29
Nov 27, 2010 11:58 AM
jeffjones08f4i
Sep 10, 2009 09:00 AM
