2000 HONDA CBR600 F4 starting issue
Old Apr 25, 2024 | 06:55 PM
Shadow1238's Avatar
Default 2000 HONDA CBR600 F4 starting issue
Hey everyone. I’m new here so hopefully this is the right place. I recently bought a used 2000 Honda CBR 600 f4. The bike has some trouble starting and idles rough at about 500-700rpm and the battery dies after like 5 attempts of starting it. I’ve got it to run on without a boost here and there but the moment you drop it into gear and let go of the clutch the bike will move a few feet before the engine dies out. The bike often times won’t start without a boost but I have got it running and driveable with a push start. After a push start the bike drives completely fine. It’s just getting it to that point where I have a problem. I have a video of the bike idling that I can send upon request. Unfortunately the video is too large to post on here.
thanks for all the help in advanced. Any advice or ideas as to where I should look or what I can do is greatly appreciated
Old Apr 25, 2024 | 07:38 PM
dannoxyz's Avatar
Post video on YouTube and put link to it here.
Did you dump tank and get fresh petrol?
Completely disassemble carbs for full restoration job?
Probably needs new battery. They don't come charge, so be sure to trickle-charge new battery for 24-hrs before installing.
Old Apr 25, 2024 | 08:25 PM
Shadow1238's Avatar
Thanks for responding. I completely emptied the tank and filled it with new 94 Premium fuel a day after purchasing the bike. I bought a completely new and charged battery shortly after the problem started so I don't believe the battery would be the issue.
I have not taken apart the carbs. Is it a simple process? Truthfully speaking I am not very mechanically knowledgeable so I don't want to get ahead of myself and then end up screwing up the bike even more. If it is a complicated do you have a link or a different thread I can use a guide on how to take apart the carbs and do a full cleaning?
Appreciate the help.
Old Apr 26, 2024 | 11:03 AM
dannoxyz's Avatar
Don’t use any higher octane than what manual says. 94 is more stable and more difficult to ignite. That’s partly contributing to your starting problems.
Takes lots of experience and specialised equipment to overhaul carbs. Need to destroy at least 10 sets of carbs getting that experience. Best to send carbs to pros for restoration. Expert workmanship, reasonable fees and quick turnaround. Bike will run like brand-new off showroom floor.
https://customcarbservices.com
Old Apr 29, 2024 | 10:57 AM
First off you should adjust the idle speed, it is way too low. Not surprised that it is stalling all the time.
The manual states 1300 rpm =/- 100 rpm. (non CA Model)
Certainly needs a new battery
Old Apr 29, 2024 | 12:47 PM
dannoxyz's Avatar
Yeah, keep battery on trickle-charger 24/7. Shouldn't die after 5 attempts.
1. measure battery voltage with everything OFF, volts = ???
2. measure battery voltage during cranking, volts = ???
Old May 1, 2024 | 12:08 PM
samdhxu's Avatar
I'm experiencing a ton of difficulty with this bicycle. fourteen days before it passed on, I supplanted each of the four flash fittings. Upon substitution, the bicycle fired up fine and rode all around well.
Kodi
Aron
Mar 4, 2024 06:53 AM
Xavierf4
Jun 16, 2018 09:42 PM
Red_Wingz
Oct 27, 2012 11:38 AM
Mattm
Oct 15, 2011 04:28 PM
OrangeblazeF4
Nov 15, 2005 04:02 PM
