2000 Honda CBR F4 throttle problem
Old May 12, 2012 | 03:59 PM
codyw2012's Avatar
Default 2000 Honda CBR F4 throttle problem
Didn't post it directly under that forum because I figured it was a broad problem that some experienced techs could help me with. I was out riding my bike today. I shouldn't have been because I was slightly angry, but i rode pretty much normally. As I was hitting my homestretch, i pulled the throttle back for a little exta, hit about 80, then lost all my momentum. My throttle wasn't working. I have been riding it about 3 months with no problem. And they are aftermarket grips on the handlebars. to get it home, i had to squeeze the very end of the grip and pull it back for slight throttle. there wasn't much. The grip has always been a little sticky, as in i could let go and it would keep the same throttle for a few seconds before it came loose. What are my options ? The grip is completely broke now. It just spins.
Old May 13, 2012 | 07:56 AM
Lacking any photo's or videos I'd say you just need to replace item #10 located here. It should be an easy replacement.
Old May 13, 2012 | 09:51 AM
zaqwert6's Avatar
Nov 2011 ROTM
Is it the plastic sleeve of the throttle mechanism itself that's broken, 'slipping' or are you saying the grip (rubber) is spinning on the sleeve?
Old May 15, 2012 | 06:29 AM
xtremef4i's Avatar
If the above isn't it, it could be a Worn throttle cable. Hard to say without seeing it or riding it in person...
jdub22
F2 Tech
May 22, 2011 08:49 PM
kharvey
Aug 24, 2010 05:23 PM
kharvey
Aug 20, 2010 10:10 AM
STBrider91
Jun 3, 2009 08:26 PM
leonaro111
May 19, 2005 02:04 AM
