1995 F3 No start.. then start...
Old 07-19-2006, 11:13 PM
atrious333's Avatar
Default 1995 F3 No start.. then start...
My 1995 CBR F3 was running great last year. I rode it once at the begining of the year and it stopped on me. I tried some carb cleaner and changed the plugs. Started right up. Ran it for the day. I had to jump it. I stopped it and checked it again to see if it would start. It did. I put it away for a couple of days. Put a new battery in and moved it. Now it doesn't start again. The only thing I know that was done with it is the guy before me laid it down twice, (only cosmetic) and he put an aftermarket pipe on it. I called the shop and they said it may be that the bike wasn't "tuned" for the new pipe. They want $500 for it. I was thinking of trying to put the stock muffler back on. Is there anything else I can try instead? Thanks for the help.
Old 07-20-2006, 12:20 AM
slowpoke's Avatar
Default RE: 1995 F3 No start.. then start...
Save the $500 for gas. An intermittent problem is usually electrical and is usually a bad connection. I would clean all the safety switches that can shut off the ignition like the kickstand, neutral switches, etc.
Old 07-20-2006, 02:57 PM
a pipe has nothing to do with it check all fuses and connectins, check battery connection as well
Old 07-20-2006, 06:02 PM
atrious333's Avatar
I can find my way around my truck, but this bike thing is pretty new. How do I go about checking these switches, and how do I know if they are bad. I'm guessing the fuses are just like a cars... that won't be a problem. Could this be why the battery is dying more than usual?? The terminals are clean. Thanks a lot for your help!
Old 07-20-2006, 06:07 PM
atrious333's Avatar
Sorry.... My friend reminded me. The bike is attempting to start. In fact right before I changed the spark plugs if we would get a backfire after four or five times. I know if we keep on trying to start it eventually we will have to change the battery and the spark plugs. But that is about all I know. So it's not that it won't even turn, it is cranking.. just not running.
Old 07-21-2006, 09:22 AM
pacemaker's Avatar
Sounds like a faulty regulator to me.
Old 07-22-2006, 05:03 PM
atrious333's Avatar
Help me out with the regulator. Is this costly?
Old 07-23-2006, 03:13 AM
slowpoke's Avatar
ORIGINAL: atrious333
...The bike is attempting to start. In fact right before I changed the spark plugs if we would get a backfire after four or five times.
Check to make sure the spark plug wires are on the correct plugs. Number 1 is on the left when sitting on the bike, then 2, 3, 4.
supermover25
03-15-2019 08:14 PM
mlabonte
04-01-2012 10:41 PM
cbr900rrracin2012
03-21-2012 08:40 AM
Freewax
F2 Tech
03-05-2011 09:37 PM
JayBoCC2
06-23-2009 10:23 PM
Quick Reply: 1995 F3 No start.. then start...
