1992 Cbr f2 No power
Old Jul 3, 2013 | 03:43 PM
Joey Fogle's Avatar
Default 1992 Cbr f2 No power
Im 100/% new here and ive had my cbr for about two months now.. and loved every minute of it. One day I was just riding along and my bike lost power.. all of it. When i turn the key literallly nothing comes on, no light no nothing. tried bump starting it and it wouldn`t keep power and die imediatly. I know its not the battery cause i just replaced that, also replaced the regulator/rectifier, and now im just stumped and would like any advice that anyone could possible give me, Thanks
Old Jul 3, 2013 | 11:33 PM
If nothing happens at all, it's most likely the main 30A fuse. It's located on the start relay near the battery.
Old Jul 5, 2013 | 12:08 AM
Joey Fogle's Avatar
That was one of the first things i checked.. fuse was good, even replaced it just incase =/
Old Jul 5, 2013 | 06:15 PM
There is not much that will cause a totally dead bike.
  • Do you have 12v on the red wire at the ignition switch ?
  • When you turn the key to the ON position, do you have 12V on the Blue/Orange wire and the Red/Black wire coming out of the ignition switch ?
Old Jul 5, 2013 | 09:38 PM
squale147's Avatar
July 2013 ROTM
i still would load test the battery...just because its new does not mean its good...
Old Jul 6, 2013 | 09:05 PM
Joey Fogle's Avatar
Yeah i have 12v in those spots, my next thought was that maybe i have a bad ground somehwere?
Old Jul 6, 2013 | 09:54 PM
Testing the ground should be easy. Remove the ground lug from the battery and then test for continuity between the negative lead and a bare spot on the frame. You should read something less than 1 Ohm.
If you have 12v on those spots, then do you have 12v on one side of all the fuses in the fuse box ? There are 4 fuses under there.
Old Jul 6, 2013 | 09:57 PM
Joey Fogle's Avatar
in that fuse box the 15amp fuse test different then the rest
Old Jul 6, 2013 | 10:04 PM
You're going to need to be more specific when you describe something. Remember that we're not there to see and hear what you do. So you have to be able to put into words what you're seeing and hearing.
If you remove all 4 fuses, then you should be able to read 12v on one side of each of the fuse connections. Naturally you wouldn't read anything on the other side because the way it gets there is through the fuse, and you've taken them out. So when you say it's different, how do you mean different ?
Old Jul 13, 2013 | 12:06 PM
Joey Fogle's Avatar
Sorry i havent been on here in a while but if your still willing to help id love, still no progress with the bike, but ive metered a ton of things out and found out that everything is good, until i plug in the 15amp fuse in the fuse box by my throttle, right when i plug that fuse in, my voltage drops from 12v to almost 0 =/ any ideas?
