05 cbr600rr loses power at certain rpms - Page 2 - CBR Forum - Enthusiast forums for Honda CBR Owners
Go Back  CBR Forum - Enthusiast forums for Honda CBR Owners > General > General Tech
Reload this Page >
Old 02-24-2019, 07:23 AM
CaBaRet's Avatar
Found a video to show the firing
Old 02-24-2019, 07:34 AM
Wow thank you. So would I see if one or more injector is firing less than the others. Or also one that is not firing at all. ?
Old 02-24-2019, 07:51 AM
CaBaRet's Avatar
Yes you should it comes out with quite a force, if al are firing , it will have to be somewhere else even the fuel pump
Old 02-24-2019, 08:03 AM
Thanks a lot. I will check that out and get back to you. I appreciate it
Old 02-24-2019, 06:26 PM
Seem fine to me. I took the air box off and did exactly what that video you showed me did and look just fine. I took a video of it to show you but canít seem to upload it here.
Old 02-24-2019, 11:18 PM
CaBaRet's Avatar
Hi , you could try a Fuel flow inspection page 6-57 of your manual , that should tell you if your getting the correct amount of fuel through in a given time, should point to Pump or clogged fuel lines if not,
Old 02-25-2019, 06:33 AM
74demon's Avatar
Have you ever checked/adjusted your valves? At 35k, it should have been done twice already. Tight valves can cause random misfires and risk valve burning.
Old 03-11-2019, 09:51 PM
Ok so an update is due. I started doing some research and I decided to check to see if there were any codes. Y I didnít think of that befor is beyond me. So I located the service port under he seat and jumped the brown and green wire and turned the key and my mil light started blinking after watching very closely I wrote down the codes and it was.......
2 blinks- 7 blinks- 9 blinks- 16 blinks- and 49 blinks
which was a malfunction of IAT sensor. ECT sensor. MAP sensor and secondary injectors 1 and 4.
So I got my meter out and considering Iím an electrician I figured WTH i can figure this out. Thinking that there no way that all of these components were bad all at once tells me that there might be a grounding or connection problem. So I downloaded the entire service manual for my bike and went to town. Check continuity of every sensor. Voltage on the harness side. Resistance of the sensors. Everything just fine until I found a wire from my map sensor I couldnít get a reading from. Traces it to the ECU and wala found a loose pin. Fixed it cleared the codes and now itís fine. Crazy!!
Old 03-12-2019, 12:33 AM
CaBaRet's Avatar
Well done ,
Old 03-15-2019, 04:21 PM
Gunk's Avatar
itís always something minor, itís just finding it.
Mikeray35
04-14-2014 04:08 PM
ShotByAdam
08-17-2012 03:14 AM
Straussy
07-06-2012 12:31 AM
The_Prince_NR
F2 Tech
14
02-25-2011 07:14 AM
abrooks09
06-22-2010 04:11 PM
Quick Reply: 05 cbr600rr loses power at certain rpms
Featured Sponsors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
