05 600rr no start/fuel pump issue/relay seems alright
So here is the the deal...
-I turn on the bike and flip the kill switch and i hear a click from the relays and my fuel pump does not engage. Occasionally after flicking the key on and off many times the click will stop and the pump will engage but then the bike also just randomly dies and the clicking relay continues. I took the relay out and tried it with one that I know to be good and still have the same problem. The relay that is clicking is the one plugged into the brown wires for those of you who might ask or be wondering. Does anybody have any idea as to what might be going on here and how I can fix it? It's actually painfully driving around with four wheels as the days are still bueatiful and my bike can only sit. Any help on this is GREATLY appreciated. Thankyou very much! -BERG |
RE: 05 600rr no start/fuel pump issue/relay seems alright
any updates?
i have a F4i, when i turn key, i get all lights, and the FI light... no prime, no fuel. it cranks.. all fuses are good... wont run.. same ****ty situation. |
Either your battery is low or at the point it cant support that much power and needs to be charged or you fuel relay is out.
There's a known problem with the Honda tip sensors too. Might do a search on that.
HEY THERE. I'm having a similar issue but my issue is I'm not getting a fuel pump prime sound when ignition switch on the ON position. I check my wires going in to the pump and the brown with blk wire has 12v but on the other side of the connector that goes to the pump it drops down to 4.35 volt. Ive seen a lot of threads stating about a pink wire off the ignition switch that a diode goes bad but my cbr is a 05 which means it only has 2 wires coming out of ignition. I also checked both wires coming out from my ignition switch and both wires have 12volts. Ive already by pass the bas and the kick stand and still get no fuel pump priming sound as well as I put str8 power to the pump to assure that it is working and it does make the usual priming sound.
any help would be appreciated.. THANK YOU ALL |
