02 f4i Stalling when cold
Hey guys,
I got an 02 f4i that stalls when cold. If I don't let it get to about 150 degrees. it will turn off at stop lights or when slowing down. it doesn't do it at idle so I am not sure what is going on? I did order a new fpr and it will be saturday. do you think that could be the problem. |
if your fi light throwin a code?
mine is throwing a code right now and it causes mine to die when ive already been riding and turn it off and go to restart it after a couple mins. i have to hold the throttle untill it kicks that auto warm up cycle then its fine. or, if i let it sit more than 20 min it just idles low untill that warm up. then itll go up to 3k and work its way back down to 1300 in a min or 2. my code is for the map sensor but yours may be in that area. maybe a vaccume line or bad connection.
I don't see any codes. but yeah if I let it warm up to about 150 or higher before riding I have no problems. If I leave before that It stalls when I get to stop signs or lights. I hate having to start it while riding.
Originally Posted by Mruiz0405
(Post 884454)
Hey guys,
Is there a IAT or MAF/MAP sensor? I would test them or clean them up. Sounds like one of those issues.
you might wanna check your vaccume lines. i just had my tank up to adjust my cct so i checked everything out to see why my light was on and found a tear in the vac line to the map sensor (left side of airbox). fixed the line and no more stalling on mine.
| All times are GMT -5. The time now is 07:25 AM. |
