02 F4i engine or fuel problem?
Didn't know if I should post this up in this section or not but here is a link to my other post, any help is greatly appriciated!
https://cbrforum.com/forum/f4i-main-forum-11/new-guy-needs-help-fuel-engine-problem-111953/
that sounds like bad news man usually when you got a problem where one fluid is gettin into another fluid in the motor, means that theres a crack somewhere, like when you crack the block on a car you get radiator fluid in the oil, i would take off the tank empty it completely out put fresh gas in there maybe with some injector cleaner, do an oil change let the old stuff drain for awhile to get it all out change the plugs then try and light it up again, if you start have'n the same problem i'd call your local shop see what they have to say
Yea I'm kinda hoping it's not that big of a problem but with my luck lately I'm sure it's gonna be... I was thinking about changing the oil, plugs and the fuel pressure regulator and run some injector cleaner and see if that does anything... The bike is apart right now sitting in the garage, I'm trying to do research before I start buying parts. Found this and it seems similar to my problem...
http://www.fireblades.org/forums/hon...ease-help.html
Thanks! I just ordered new plugs and a fuel pressure regulator today. I had another question though, how can you clean a fuel injector besides running fuel injector cleaner in your gas? I think one might be stuck open and if I could clean it while everything is apart that would save me more then a few four letter words.
The chicken strips are there cause I start scraping foot pegs after a certin point... But after the neighbor heard about this issue on my bike he went to his garage and came back with 2 brand new pilot powers and said I could have em. He was like sorry I can't help you out but here is some new meat... It's gonna feel weird having a new tires but I can't wait to get this thing running so I can toast my old tire
now thats a good neighbor! yea i know about hitt'n the pegs i did the same thing on mine when i took it to ride the dragons tail i still had the stoppers on the bottom of the pegs busted both those off with about 10 feet of sparks on the road made the heart jump a bit haha!, i found one of em and thru it at the bottom of the tree of shame, cant wait to take the new bike out there.
