01 F4i Cracked Fork Damper? (pics)
Hi All,
I am replacing my fork seals and, after disassembling the front suspension, found something unusual with the front right damper. These are probably two fairly obvious questions, but, after loooking at the pics:
1) safe to say that's a hairline fracture?
2) safe to say that would be a problem and needs to be replaced?
http://www.flickr.com/photos/cmurph/tags/forkdamper/
The bike has about 35k on it and has been in one low speed accident at an intersection... could this be caused by normal wear/tear/stress... or more likely a crash or other abrupt impact? Thanks for looking!
![](http://farm4.static.flickr.com/3537/3316294743_095349a780_b.jpg)
![](http://farm4.static.flickr.com/3460/3317120884_a03d6197e9_b.jpg)
![](http://farm4.static.flickr.com/3557/3317122106_91ec648e60_b.jpg)
Has the bike been in a front end collision? Stunted? Were both legs leaking?
Check over the rest very carefully to make sure you dont have anything bent, cracked or pitted.
Can you feel or see if the crack goes all the way through or is it some kind of scratch on the surface?
