CBRclassic |
12-10-2009 04:09 PM |
How to put a pic/banner in your Signature
The detailed long version ... read carefully and do not try this at home if you are drinking ...LOL:icon_teeth:
Signatures and Sig. Pictures are the tag line or caption that appears at the bottom of your posts. To load or edit your Signature, access the User Control Panel, click on the top control in the menu on the left, and use the vBulletin editor to compose your Signature.
For loading pictures in particular, scroll down below the Signature Editor window till you reach the Signature Picture download feature. There are two options here for adding a picture to your Signature.: NOTE: You must be in "Enhanced Interface - WYSIWYG Editor" mode to insert a signature.
Set this in your own user CP options ..
Option 1: If you have images posted on a website such as Photobucket… - Type or paste the URL of the image into Option 1;
- Click the “Save Signature” button - BUT !! you're not close to done yet!
At this point, the image is still not added to your signature but it will show in the “Your Current Signature Picture” window immediately above;
- Now click the link next to the picture that says “Insert Signature Picture”.
This will insert the appropriate code into the WYSIWYG editor editor box above;
- You may now add additional text, if desired, around the image code;
- Then click “Save Signature” or “Preview Signature” and you're done!
Option 2: If you wish to load an image saved to your computer hard drive…- Click the “Browse” button next to Option 2;
- Locate and highlight your picture in your directory;
- Click “Open” or “Save” in your directory window;
- Then click the “Save Signature” button - BUT!! you're not close to done yet!
At this point, the image is still not added to your signature but it will show in the “your current signature picture” window immediately above;
This will insert the appropriate code into the WYSIWYG editor box above;
:icon_wink:
