F4i Forks & Triples - New seals, fluid, etc
All done on 4/30/2012
New OEM Honda oil seals and dust boots
New OEM Honda inner guide bushings
New OEM Honda lower damper bolt crush washers
New OEM Honda 10W fork oil
Flushed and cleaned outers inside and out. Finally flushed with alcohol to remove any residual solvents/moisture.
No gouging or rash anywhere, all adjustment ***** look good. If you used a carb or brake cleaner you can probably get the rest of the brake gunk off near the caliper mounting points.
Triples: comes with bearings(I would replace though but that's me...they're open ball bearings so they've just been exposed to whatever lingering around), horn, bridge, nut, and even the stem cap. Everything is great here...ZERO miles on servicing. Before that...10,000miles. Went with a ZX6r front end a while back and just got around to rebuilding these.
$225 shipped
$225 shipped
really like to get the whole setup out of my garage. Provided I can actually move the triples then I could probably do that...I'll knock off $35...190 shipped for just the forks
oh and fellas, if you need pics I'll upload some to my photobucket, seems the pics that I had on there before aren't loading anymore. Junk free photo hosting doesn't last long :/
Forks are located in Greensburg, IN.. FYI
cool. i'll take the forks for $190. everything is in good condition? all of the threads are good (fender, pinch bolts, calipers)?
how would you like me to pay you?
what's the link to your photobucket with the pics?
Yep, all threads are fine. All 4 axle pinch bolts are actually still in the lowers. Paypal is preferred
