Is your second gear SENSITIVE like mine?
RE: Is your second gear SENSITIVE like mine?
What do you mean you have to be careful? Are you not pulling the clutch all the way in before you start the shift? And the shift from 1st to 2nd should be quick and firm, shift right through neutral. Then release the clutch. Poor shifting techniques will exacerbate grinding your gears at higher RPM's. So, check your shifting timing.
Unlike my truck, I don't think I've ever ground the gears on my bike.
