Yoshimura Slip-on w/ 02 sensor question
I just picked up a Yoshimura slip on for my Honda f4i... It has the 02 sensor attached to it.
My question is... Can I use the old plug from my stock pipe??? Or should I use the plug that came attached to the Yosh pipe? Will it make any difference? Thanks for the the Help given |
Any help guys?
Are you saying it came w/ an O2 sensor already screwed into the pipe? I'd think you could use either, but it would be easier just to use the one that came in the pipe.
Yes, the Yosh came with the 02 Sensor already attached to it. I just took the one that was plugged into my stock muffler off and bolted it onto the yosh pipe.
are all the 02 sensor cords the same? or do they send different information to the bike? |
They should be the same, I don't know why they would alter it. Which pipe did you get, yoshimura has directions online for the install?
