Would a tight chain sound like rattling around 5k RPM?
Old 11-05-2007, 09:39 PM
muckdawg24's Avatar
Default Would a tight chain sound like rattling around 5k RPM?
The reason that I ask is because 1, 2, and 3rd around 5-6k there is a rattling sound. I thought it was maybe just some vibration but after reading these CCT and chain slack posts I am beginning to get concerned. My bike is an '06 with only 6k miles on it.
Old 11-05-2007, 09:43 PM
dwschultzy's Avatar
Default RE: Would a tight chain sound like rattling around 5k RPM?
CCT. Do a search. There is a ton of info in here.
Old 11-06-2007, 01:10 AM
Well I hear a smooth hum on mine! I wouldnt play around, take it by the dealership and talk to them for sure! I wouldnt linger! You would hate to be riding and your chain goes, who knows what the end result could be!
Old 11-06-2007, 09:41 AM
Streetdemon's Avatar
I ♥ CBRF
Yeah a tight chain can make some noise but it's more then likely a dirty chain. Clean and lube that baby up. How much slack do you have on the chain?
Old 11-06-2007, 05:30 PM
Sounds more like the cct to me.
Old 11-06-2007, 06:44 PM
FLYOU's Avatar
where's Jared at? He's got some sort of custom CCT chain that's rattle free. i want one of those!!
where'd you get it at Jared?
Old 11-06-2007, 07:56 PM
rodantking's Avatar
Bad chains make more of an oscillating sound. If you think it's it though just loosen it way up and check for tight spots. Chances of haveing a chain that bad in 6,000 miles is not good. Adjust to the loose side of right (tight chains eat final drives) and change the cct
Old 11-06-2007, 09:16 PM
muckdawg24's Avatar
I did a whole bunch of reading on the CCT and it def sounds like a can of bb's around that rpm range. I also noticed on ronayers.com that there are four or five variations of the CCT. Guess they have figured out they make a ton of racket. Anyone happen to have the latest generation CCT?
FYI, I measured the chain and it's a little over an inch of slack.
Old 11-06-2007, 09:43 PM
FLYOU's Avatar
just to make sure we're all on the same page:
this rattling is harmless for the most part, correct? my bike does it a little too... (i think they all do)
Old 11-06-2007, 09:49 PM
muckdawg24's Avatar
ORIGINAL: FLYOU
From what I read yes, I might try the mod on the pin to see if that reduces the rattle (damn it's annoying).
Quick Reply: Would a tight chain sound like rattling around 5k RPM?
