rainbowkrash |
04-16-2012 09:04 PM |
wont crank, will start.
Hey guys. So I had some trouble a few months ago, the battery charger was left on 30amp jump for like 3 days, blew the battery up. The bike wouldent start, everything was jacked. I replaced the starter relay, the battery, all the fuses. now heres what happens, I can turn the ignition key on everything appears fine. If I hit the starter button, nothing at all happens BUT if I jump it at the relay, the bike will start and run.
I have no tipover sensor, no clutch sensor, I do have neutral (its good) i do have kickstand (also good), and my kill/starter switch is off an RC51 (maybe bad?). those mods have been done for years, and there is no problem with them. I read something about diode? I dont know how to check that. Also there is two relays in the back that i have not replaced.
This is a real doozie to me, I cant figure out what it is. I tried jumping the wires at the plug for the starter switch.. but no dice, but I may have done the wrong wires? I think its yellow and red to black and red, something like that. I suck at electrical system basically. LoL. I just replaced all my shift forks with the motor in the bike (it can be done, easily. And the gear changer shaft.
