wiring for an integrated tail light!
RE: wiring for an integrated tail light!
I had a similar problem, and if you have aftermarket front blinkers with only two wires then you can only hook up you negative the green wire and the positive turn signal wire the other positive wire is the running lights and if you try to use that with the integrated rear light it will screw everything up so, basically the proble in your rear blinker is because of your front blinker because they are connected so disconnect the front running lights
