Wiring help to run high beam only instead of low
okay guys here's my problem...
I got HID's... the way the headlight housing/reflectors are made makes the high beam focused on one spot (so i aimed them to the ground), and the low beam shines off everywhere (pointed to lowest level but light still shines off and blinds ppl).
Since it blinds people... I wanna rewire my bike.
Normally, the light switch, when I set it to low beam, the left side (low beam) turns on only. Then when I set the switch to high beam, the right side (high beam) turns on.
I want it the other way around so that when I set it to low beam, the right side (high beam) turns on only. This way, at night, I can run with the high beam pointed on the ground and not blind anyone. And I'll use my low beam as a high beam because the lights shines the entire neighborhood.
confused?
if u aren't... any good input would help.
confused?
