which wire harness do i need?
Old 05-28-2010, 09:04 AM
Default which wire harness do i need?
theives tried to steal my bike last week, and in doing so they cut the 4 wires (ignition wires im guessing) that lead up to the key and bridge. I spliced them back to gether ghetto style just to be able to ride the bike, but they should really be replaced.
Here is a diagram of all the wires on the bike:
http://fiche.ronayers.com/Index.cfm/..._HARNESS_01-03
i cannot figure out which wire harness i need that will replace these 4 cut wires.
if you guys can help me out that be great, thanks
Old 05-28-2010, 09:15 AM
redzintimidator's Avatar
Just Solder and shrink wrap the wires back together, it will be better than new! If you need to add additional lengths of wire in, make sure its the same gauge wire as the existing wire. If you need help how to do this, i can write up a tutorial :-D
Old 05-28-2010, 04:56 PM
bump...for more useful information and for someone that can answer my question
Old 05-28-2010, 05:01 PM
letsride's Avatar
I can check when I get home if I still have mine,maybe I can be of more help that way.
Old 05-28-2010, 05:38 PM
Kuroshio's Avatar
Where exactly did they cut in? Did they cut the bike's actual harness?
The ignition has its own wires and connector. If they cut at that point, you can only buy a new switch assembly: 35100-MBW-673 SWITCH ASSY. Item #3.
If they cut the harness, I think what you're looking for is item 7 on the link you supplied. The front sub-harness
Old 05-29-2010, 08:51 AM
great! thanks i will most def buy it off ya
Old 05-29-2010, 08:54 AM
i wish i could take a pic for ya but the bike is up at a friends house because i dont have a garage. i wont be able to see the bike until next thursday...but i will try and explain what wires:
the theives cut the 4 wires that come directly out of the 'key box unit' ( i dont know what the technicall term is). Where you place your key and 'turn' if you follow down about 3 inches past the bridge you will see a set of wires, THOSE are what got cut. i believe on the wires its written "ground" "power" "ignition" and i cant remeber what the forth is. but you get the idea
thanks for your help
Old 05-29-2010, 09:34 AM
Kuroshio's Avatar
If they cut it before the connector, side closest to the key, it's not part of the bike's wire harness. That's part of the ignition assembly. Learned that the hard way wiring up my first alarm
Old 05-29-2010, 01:09 PM
letsride's Avatar
Sounds like you need either a new ignition or splice the wires back together as previously explained.
Yin-Yang
F4i - For-Sale / Trade
05-18-2014 12:42 AM
Boyo
03-02-2012 11:45 PM
coldflood
10-16-2011 10:31 PM
dunnanunnanunnamattman
04-05-2011 06:00 PM
ldgriffin
09-18-2010 05:29 PM
Quick Reply: which wire harness do i need?
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
