Why can't I get past neutral?
It seems every time that I get on it from first and go to shift through the gears it gets stuck in neutral and I just rev the crap out of it. Its not every time but alot of the time.. did it 3 times today to see if I could figure out the problem. Anyone else?
How long have you been riding?
I ask because I did that a good number of times when I first started riding. I quickly learned to lift my toes up harder when shifting. Even into higher gears. Don't be afraid of shifting too hard! |
+1 Also, you can lower your shift lever, which helped me out. But it still happens (rarely :icon_confused: ) lol
I had that same exact problem when I first started out riding; I would sometimes shift and get stuck in neutral and rev it and look like an idiot, but with more experience, the easier it comes, although rarely will that still happen to me now, I find that it only happens when I get lazy. Bikes are meant to be ridden hard. Don't be afraid to shift hard, the bike will appreciate it rather than you pushing the shifter a little and then CRUNCH, grind the gears.
hmm i personally never had that problem but id have to agree with the rest of them... although there could be something else who knows... i know when i jump on my buddies GSXR 750 its its hard to throw it down to first... could just be a the bike...who knows... let me know when ya figure it out....
I have rarely had that problem (like said above...when getting lazy). It has happened maybe 5-7 times in the 2 years I have been riding. I wear steel toe boots all the time. I have heard from people that it is easier to shift with boots on as apposed to shoes. What footwear do you have? Just a thought.
Yeah, sounds like you're just not popping it up hard enough. What everybody else said- what shoes are you wearing and check your shift lever, maybe you just need to adjust it a bit.
lower the shift lever
+1. Don't change your shoes (unless they're not appropriate for riding), just lower your shifter. You can make major adjustments by rotating the clamp that attaches to the trans, and minor by twisting the connecting rod. That's all just part of setting a bike up to fit you.
Originally Posted by Uniqsol
(Post 807393)
To answer a few other questions.. Ive been riding for about a year I think, second bike. Id say some boots which ive wanted anyways to harden my toe, and lower the shifter I should be ok? |
