Whole bike vibrates???
Hey,
So the problem seems to be the whole bike is vibrating?
I feel it in my feet, seat and hands, but I ruled out inbalanced tires due to if I pull the clutch in the vibrating stops.
Also I replaced the CCTL with a OEM automatic one about 12,000km's (7,500mi) but there is a noise now not as loud as before when I replaced it. Its more of a buzzing the a rattle like before? Could that make the bike vibrate or is their another culprit.
Cheers
Cheers
Has anyone had vibrations problems when the CCTL started to go?
if it's mostly between 4-6K RPM then it's definitely your CCTL. APE FTW
The motor has never been taken apart during my ownership so hopefully it nothing like that. The buzzing started a couple weeks ago, all signs point to the CCT but last time I changed it, it was rattling and this is more of a buzz between 4-6Krpms.
Something's loose or about to go. And by go I mean cost you tons of money.
The CCTL is basically an annoying rattle, nothing more. In terms of "bike is vibrating."
Does the throttle respond like it always has? Like the bike delivers full power like it should? Any range where the vibration gets worse?
(It stops when you pull in the clutch which slows the engine to idle. It's something wrong with your engine)
Throttle response is same as it has always been and it has all the power it should. The vibration is not like a Harley jerky vibration but more of like a buzzing vibration, it can be felt in the footpags and bars and a little in the seat, It starts around 4.5k rpm.
Maybe I'll just take it to Honda and see what they think and go from there.
