Whinning sound after sprocket change
LIke it says I am noticing at bit of a whinning sound only when accelerating and I dont know if it has always been there and I am just trying to hear something out of the ordinary just being cautious. Doesnt anyone have anything remotely sounding like this going on ? I went -1/+2 with a new chain and I dont know it rides prefectly fine i have probably put 100-150 miles on the set-up and noticed it. Any advice or suggestions would be great. Thanks
RE: Whinning sound after sprocket change
A friend of mine had the same issue on his 900 rr. It ended up being that the new sprocket didn't have the same spacing on the inside as his old one. It doesn't hurt anything, it runs fine it's not rubbing it's just a little bit off from stock, and that makes it wine when he accelerates. Check the spacing on the old sprocket, and the new one to see if that might be causing the issue. Again, it doesn't seem to hurt anything unless it's making it rub on something.
bowtieboy42
F2 Tech
07-10-2012 03:53 PM
arnriis
08-21-2008 03:58 PM
