What are they symptoms of throttle bodies out of sync
I've tried searching the above question but can't seem to find an answer.
Any help would be great. |
throttle body sync is fine tuning of airflow when the throttle plates are closed. main symptom of bad sync is a poor idle. it only smooths out idle and initial off idle acceleration.
the f4i is extremely easy to sync compared to other sport bikes |
I wonder if mine need doing then, idle is fine but when I pull away in anything below 3000rpm it bogs down like crazy
i doubt that's a throttle body sync issue...
What problem do you think it could be?
A poorly running engine, which can be caused by many many things.
