What MC can be used and keep the F4i Lever?
RE: What MC can be used and keep the F4i Lever?
That is something you are probably going to have to try for yourself. Can you be more specific in what you are doing with your bike. Which master cylinder are you looking at getting? A good trick is to check with pazzo (nice levers) and see if the part numbers are the same for the MC you are going to versus the one you have. If they are different chances are it won't work, or at least work well.
Yeah, I'd recommend a reverse part# search.
FWIW- the stock brake lever for F4i shares the same part# for VTR100F, F4, VFR800, CB600F. Part # is 53170-MBW-006
I'd be willing to bet that you could use the Pazzo with any of those MCs. If it comes to it, you could always sell your Pazzo on eBay and get the MC that you really want.
Good Luck.
Good Luck.
ORIGINAL: bluej511
So is the MC and lever (from wtv i decide) just a direct swap bolt on just switch brake lines and brake switch? What fits the best for the f4i because i honest to god hate the feel of having to squeeze a bit for anything to happen.
I changed my MC because of inconsistency, but the brakes were otherwise Tiz-ight. I took them off and I'm mad cause I think my problem was a stuck caliper the whole time. It will be posted for sale soon.
