-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   What forks fit on the f4i? (https://cbrforum.com/forum/f4i-main-forum-11/what-forks-fit-f4i-11069/)
Turboedsupe Mar 24, 2006 12:06 AM
Does any other bike have the same forks as a f4I? I thought the F4's had the same ones but someone told me otherwise. Someone else said gsxr 600's fit, does even the new f4i's with the bannana seat fit?
DThompson Mar 24, 2006 04:34 AM
RE: What forks fit on the f4i?
Im not really sure about this one. You should check out some MOTO GP sites. Alot of times they put different Forks on their bikes.
Daniel Thompson
chaos321 Mar 24, 2006 04:49 AM
The F4 forks are exactly the same as the F4i forks. The difference is the wheel, rotors, axle and spacers. That's it!. I know the 929/954 forks will fit with a little work at the stem, a buddy had it done a while back. I'm not too sure about anything else. I doubt the gsxr forks will fit but with the right stem work I suppose it's possible.
vtec97hatch Mar 24, 2006 02:44 PM
i was wondering the same thing. i've seen a few f4i's in stunt mags & videos with inverted forks, and the closest thing i can see that they resemble is the 929 forks. keep the posts comin' and let us know.
wantafastf4i Mar 24, 2006 04:05 PM
pretty sure they use the 929 forks b/c they have bigger and better front brakes for those extended stoppies. Not positive but thats what ive heard i believe.
kup125 Mar 24, 2006 08:39 PM
yes the 929/954 forks are a good upgrade if youre are going the stunter route
TonyC Mar 24, 2006 09:55 PM
i have 954 forks on my f4i. Gsxr forks will mount up as well. Not sure what years exactly. F4 will work. 600rr will mount up but the steering stops wont allow it to tun far enough in both directions. im pretty sure the 1000rr fors will mount up too.
Turboedsupe Mar 24, 2006 11:45 PM
ORIGINAL: chaos321
I found a real cheap set of forks from a f4 im just worried there not going to fit. So your saying if i got the f4i wheel, rotor, axle, and spacer that it will all bolt up to the f4 fork and my bike?
Turboedsupe Mar 24, 2006 11:54 PM
Nevermind im going to get these 954 forks for my new bike im getting thanks guys
TonyC Mar 26, 2006 12:53 AM
ORIGINAL: Turboedsupe
your gonna like em
