-   F4i - Main Forum (https://cbrforum.com/forum/f4i-main-forum-11/)
-   -   What is this? (https://cbrforum.com/forum/f4i-main-forum-11/what-164439/)
MattJ Jun 28, 2024 03:51 PM
What is this?
Hi all,
Really need your help with this, I've tried searching Google but have had no luck, does any one know what this is?
​​​​​​Any help would be greatly appreciated.
Thanks
https://cimg2.ibsrv.net/gimg/cbrforu...1aade6f6ab.jpg
Ed Harris Jun 29, 2024 06:51 AM
It looks like the pipe from a Scotoiler
dannoxyz Jun 29, 2024 09:57 AM
Where does lower-end attach?
Al1040 Jun 29, 2024 03:06 PM
Welcome to the forum.
+1 on the scottoiler pipe... clearly without the oiler!
Bike will not run well as that will be a vacuum pipe that is now open to the air.
MattJ Jun 29, 2024 03:21 PM
Thank you for your help guys.
I really appreciate it 🙏
MattJ Jun 29, 2024 03:31 PM
If I wanted to get rid of the scottoiler pipe and get it back to how it would have been before, does anyone know where or how it goes?
Al1040 Jun 29, 2024 03:37 PM
It will come from a tap off from the throttle body. A small screw will have been removed and replaced with a vent adapter (same as if you were performing a carb balance).
Take adapter out and replace with screw or cut pipe close to throttle body and clamp the end to seal it.
Not sure I have describe the terminology correctly, but hopefully you will get the drift!
MattJ Jun 29, 2024 03:41 PM
Yes I get what your saying, thank you so much I've been searching and searching trying to figure out what it was will get it sorted tomorrow 👍
