What is this?
Old Jun 28, 2024 | 03:51 PM
MattJ's Avatar
Default What is this?
Hi all,
Really need your help with this, I've tried searching Google but have had no luck, does any one know what this is?
​​​​​​Any help would be greatly appreciated.
Thanks
Old Jun 29, 2024 | 06:51 AM
Ed Harris's Avatar
It looks like the pipe from a Scotoiler
Old Jun 29, 2024 | 09:57 AM
dannoxyz's Avatar
Where does lower-end attach?
Old Jun 29, 2024 | 03:06 PM
Welcome to the forum.
+1 on the scottoiler pipe... clearly without the oiler!
Bike will not run well as that will be a vacuum pipe that is now open to the air.
Old Jun 29, 2024 | 03:21 PM
MattJ's Avatar
Thank you for your help guys.
I really appreciate it 🙏
Old Jun 29, 2024 | 03:31 PM
MattJ's Avatar
If I wanted to get rid of the scottoiler pipe and get it back to how it would have been before, does anyone know where or how it goes?
Old Jun 29, 2024 | 03:37 PM
It will come from a tap off from the throttle body. A small screw will have been removed and replaced with a vent adapter (same as if you were performing a carb balance).
Take adapter out and replace with screw or cut pipe close to throttle body and clamp the end to seal it.
Not sure I have describe the terminology correctly, but hopefully you will get the drift!
Old Jun 29, 2024 | 03:41 PM
MattJ's Avatar
Yes I get what your saying, thank you so much I've been searching and searching trying to figure out what it was will get it sorted tomorrow 👍
88caneRR
Aug 17, 2017 11:16 PM
chinakid245
Sep 1, 2009 01:19 PM
T rick
Nov 6, 2008 05:38 AM
