Weird Rattle Noise?
Weird Rattle Noise?
I just picked up a 2001 F4i last week. The bike has 14k miles on it, clean title.
Now onto my question.....
When the bike is in neutral, there is a slight "rattle" sound. When I pull the clutch in, it goes away.
Now I know on a car, that would make me believe the tob is going out (throw-out bearing), but I don't know all the inner workings of a bike so I don't even know if street bikes have such a thing.
Is this a normal noise? If not, what would cause this?
I didn't notice the noise when I first bought the bike, probably because I was too excited on the test ride....doh!
Oh, don't know if this matters, but I figure I would mention it anyways. When I bought the bike, the clutch adjustment thingy (at the lever) was all the way in and the clutch was engaging right at the very end of the lever's travel (barely had to pull the lever back to dis-engage). I went ahead and adjusted the cable at lower adjustment thing to add some slack since the upper adjustment at the lever was all the way in....
Any help/advice/things to look for would be appreciated.
RE: Weird Rattle Noise?
ORIGINAL: SchiraF4I
I know on mine when my front cover from over the tire was loose the bike rattled at a certain RPM but after i tightened it up Problem solved...
I just did a search on the CCT...my bike has 14k miles and I bet this is the issue. I guess I'll spend the $50 and see if that fixes it....
