Water Wetter vs Ice
Water Wetter vs Ice
Just curious on thoughts for Water Wetter vs Ice. I was told if i'm going to change from standard coolant to Ice I would need to drain all coolant out of the bike, (not just the radiator) before putting in Ice.
Is Water Wetter the same?
Or can you just add to what's in the bike? I live in Texas so hot 100+ deg days, and temp gets up there when stopped at a light for over a couple minutes. Mines low so need to add some, so just curious on y'all thoughts on the issue.
Thanks
Thanks
To use either, you need to get as much of the old coolant out as you can. Drain the system, fill with water, bring the bike to temperature so the thermostat opens, and drain it again. Repeat until what comes out is clean water. If you are going to use distilled water, use that to flush it the last few times.
If you looking to get temps down look into the fan temp sensor mod if you havent yet, brought my bikes temps down by 10-20degs dont think you can get that much of a difference from coolant alone.
On a related note anyone know how clear the water coming out have to be? Back when I first got my f4i I did a complete flush with distilled water running bike up to temp and all that and after three flushes it was still not completely clear (although it was very very close)
f4izombie
07-04-2011 11:08 PM
