Water pump..help
Im doing a coolant flush... and i remove well think i remove the waterpump drain screw i already drain the coolant thru the hose bt disconnecting it....and i pour water thru the rad cap but i dont see water comeing out of the pump..does someone know which screw or have pic... of which is drain.....
RE: Water pump..help
ORIGINAL: faux Im doing a coolant flush... and i remove well think i remove the waterpump drain screw i already drain the coolant thru the hose bt disconnecting it....and i pour water thru the rad cap but i dont see water comeing out of the pump..does someone know which screw or have pic... of which is drain..... |
Oman did i look but nothing like this came up i only got an RR flush...but thx
| All times are GMT -5. The time now is 02:40 AM. |
