Want to shorten my Carbon Fiber Yoshi...any suggestions?
Some of this has already been mentioned, but I'll sum up:
Measure twice, and account for how much the tip is going to cover up the end of the pipe.
Tape off with masking tape (place the tape on the side you're keeping).
Cut with a Dremel or similar tool with a small cut-off wheel.
Sand the exposed end to get rid of rough edges. If the tip isn't covering much of the end, you may want to use progressively finer and finer sand paper so you don't see any scratches.
Seal the end with resin.
Sand again as necessary.
Reassemble.
Reassemble.
Wow, that is all I have to say....wasnt really that bad of a job really...figured, added hugger tonight, added new battery...added new brake lines...added oh I mean took away about 8 inches on the yoshi pipe tonight. Looks awesome. Just pulled it in but will clean her up tomorrow and get pictures. Very worth it. The bike is going to be getting painted a pearl white with black and red highlights on her I cant wait. Taking away that grab bar also and getting the holes fiberglassed up.
Totally agree, here are a couple of before and after pics with my new brake lines also. Bike is in the shop right now getting new 520 conversion kit for chain and sprokets...also getting sliders cut for it.
Thanks!
I just got it painted last year and like the rust orange but for the money I paid I am not happy with the quality. We found a local guy that did a great job painting my buddies, 6 coats of clearcoat and it looks sick. I just am not sure totally what color...have pearl white in mind and red and black highlights somehow. Hmm....cant wait to get her back tonight with 520 conversion kit on it and see how she rides and hope the cuts are good for the sliders.
Thanks guys. Yes it was somewhat of a pain in the butt. We had to be careful on cutting the carbon because its not very healthy. But our problem was after we finally got it all cut the part of the pipe that was riveted where the slip on was still had part of the baffle there. We had to then chop parts of that out and break the baffle off. We then had to put it all back together, marked the holes with a marker on the pipe and then drilled them out. Went pretty smooth until the part where we were drilling the rivets out and a bit broke off in the pipe.....so if you ever do something like this dont use cheap bits like I tried at first. We then had to cut and drill at the broken bit until it came out. I am going to take a video today of the bike started and it sounds really good now. Sounded really mean with the pipe off though. I want to go into some type of GP or something though then I can get my spools on properly. I was so upset when I had realized our placement of my spools on the swingarm made a hole in the pipe.
