vibration while revving in neutral
Old 03-14-2006 | 10:10 PM
firebladefreak's Avatar
Default vibration while revving in neutral
guys i feel a strange vibration when i rev my 01 f4i above 3k rpm.what cud b the problem.this vibration seems to be coming from the engine.its really annoying.kindly help
Old 03-14-2006 | 11:36 PM
Icefox's Avatar
Default RE: vibration while revving in neutral
Sounds like it could be another CCTL problem. Mine was making noise so I have one on order right now, should be here on Thursday. They seem to go bad a lot in the F4i's, it's pretty much a scheduled maintenance item if you're concerned with the noise. [>:]
Old 03-14-2006 | 11:39 PM
dragonmaster_91's Avatar
Glad I own a 929 then. Haven't had any probs with it as of yet. (Knock on wood) LOL
Old 03-15-2006 | 08:47 AM
shraz's Avatar
CCT its nothing major
Old 03-15-2006 | 10:39 AM
fox where did u order ur CCT
Old 03-16-2006 | 03:56 AM
Icefox's Avatar
From my local dealership, I couldn't find an OEM one on the net so I just got it from there. It cost me about $64 for the tensioner and the gasket that went with it. It just came in today and I'm looking at it right now...damn this thing is small for that much money!
Old 03-16-2006 | 04:01 AM
Icefox's Avatar
Oh..and by the way, the part number is 14520-MBW-J23. Supposedly the J23 model is the newest model and are less likely to need to be replaced as often as the previous models...I guess I'll see about that after a few thousand miles! If you're fairly mechanically inclined, you'd save a lot by doing the job yourself, there are quite a few write-ups around with pictures too. If you don't have the part number with you when you order it, be sure to ask for the Cam Chain Tensioner *Lifter*, if you get the Cam Chain Tensioner, you'll have the wrong part and it won't solve the vibration problems.
Old 03-16-2006 | 10:17 PM
hey fox can u give me the link to the tutorial with pictures
Old 03-19-2006 | 08:11 PM
Fox's Avatar
Fox
ORIGINAL: firebladefreak
http://forums.cbrworld.net/forums/1445/ShowPost.aspx
Old 03-19-2006 | 08:29 PM
kiggy74's Avatar
Damn, that's a great tutorial. Thanks for posting.
Quick Reply: vibration while revving in neutral
