Very Bad MPG
Very Bad MPG
I have a 01 f4i with 55k on the clock (says the ODO) not sure if thats true or not. Right now I am getting about 80-85 miles till my reserve light kicks on. I'm not riding aggressive and 90% of the time I'm riding is on the highway at 75mph.
Maintenace:
Spark Plugs (NGK)
Cleaned Air filter (K&N which smelled like gas)
FPR
Oil Change
Coolant Flush
Mod wise the bike has a 520 chain conversion, K&N filter, and a scorpion slip on. I have no idea if a valve adjustment was every performed. I signed up for a Valve Adjustment clinic at the MotoShop in SF so that will be taken care of soon. I can hear my CCT rattling, but that will be replaced with the manual cct I received in the mail. Could the valve adjustment and the cct play a role in my horrible gas mileage?
Maintenace:
Spark Plugs (NGK)
FPR
Oil Change
Coolant Flush
When your fuel light comes on, is it really that low?
Does the exhaust smell like its running rich and black or grey smoke coming out the pipe?
Oxygen sensor installed or bypassed? (you said SF, m assuming its a cali bike)
Other things that can cause rich running:
Coolant temp sensor bad
Oxygen sensor bad
Vacuum leak, making the bike dump fuel to compensate
Leaking injector, would be running bad
FPR or plugged/kinked return line.
Did you remove the plug that came on the fpr before installing it?
Oxygen sensor bad
Reserve light doens't mean anything, actual gas mileage does. Fill up to a specific spot, go ride, then re-fill at the same pump to the same spot and calculate your mileage.
You said 520 conversion, you sure it isen't changed gearing as well? How many teeth do the sprockets have or whats your rpm in 6th gear at 50mph? Stock will be right at 4000rpm.
Oxygen sensor bad
Oxygen sensor bad
Yes the exhaust smells rich but not as bad as it was before I installed the new fpr.
I did remove the little plug on the fpr before installing.
I rode the bike in 6th at 50mph and it was at 4k rpms. Also the rear sprocket says 46. So I have stock sprockets.... I'm assuming the front sprocket is stock also. I will remove the cover and check and see once I get home from work.
