Undertail Replacement Lights
Hey, I'm looking to replace my undertail lights. The ones that I got with the undertail are kinda junky and trashed, and the left one is starting to fail as a running light. I'm pretty sure its a wiring problem (NOT the fault of the bulb or light housing), but I think they just look terrible and I'd like to replace them.
They're just two little bulb housings that attach from the front, and they have screw shafts sticking out of the housing that use a nut to fasten them to the undertail itself. They're about two inches in diameter, and have a clear spot at the bottom to light the license plate. I can get pics if someone wants.
I'd like something maybe a little cooler to replace them. Right now they have incandescent bulbs, but I'd like to replace them with some bright LEDs. Any ideas? Thanks a lot.
RE: Undertail Replacement Lights
Sounds like you have the targa undertail. Here is a direct replacement for the conventional bulbs. These are LEDs http://www.targa-acc.com/main_powersearch.html
2001, 600, bulb, bulbs, cbr, honda, hotbodies, light, lights, repalacement, replace, replacement, replacements, replacing, undertail, undertails
