Two Bros and O2 sensor
Hey guys i just got a Two Brothers exhaust (M2) for my 06 F4I anyone else have an issue with the O2 sensor? I can get it in but damn its tight am i missing something or is it suppose to be like that? thanks
Use some anti-seize. Wont help it go in, but will make less than a PITA when it comes time to remove it. And its supposed to be a lil tight, just make sure you ain't crossthreading it.
I put a Yoshi Pipe on my 2006 F4i, and it was pretty tight. I was about 1/4 of an inch away, but then it eventually made it. I think what happened is that the two wires were twisted farther up in the bike and eventually un-twisted and gave me more length.
I just installed the same Two Brothers exhaust and had the same issues. It also would barely reach the hole. I had to pull the wire back through and re route it so it would reach. Pull the seat off and get some small hands to work it around. Kind of a pain but once I did that it was easy.
Did the re route like matt did and it worked great thanks matt.
I also re-routed mine as well but I used the same route as its original route... I couldnt find a quicker path than the original, but it seemed to have worked it's self into the right place.
Originally Posted by loki5068
(Post 885598)
