turning off youre bike
Old 09-01-2006 | 07:39 PM
EM600's Avatar
Default turning off youre bike
when you guys turn off your bikes do you guys use the fuel cut off or do you turn the key to off
my friend said he read the manual and it says youre suppost to turn the key to off and my bike didnt come with
a manual so i thought i would ask evryone here since you guys know alot more than i do.
thanks for the help
Old 09-01-2006 | 07:41 PM
ninetyfivehp's Avatar
Default RE: turning off youre bike
use the key, not the run/stop switch
Old 09-01-2006 | 08:15 PM
roketfreek's Avatar
I just use the key.
Old 09-01-2006 | 08:38 PM
Blackdog F4i's Avatar
KEY.
Stop switch is for emergencies and does not turn off your lights and accessories. I believe the owners manual even states the key should be used.
Old 09-01-2006 | 10:27 PM
canadianF4i's Avatar
+1 For key.
Old 09-02-2006 | 06:04 AM
shraz's Avatar
it doesn't really matter which one first as long as you turn both off
You just don't want your lights draining your battery
I use the stop switch when the fan is still running and turn the key off once it is done.
Old 09-02-2006 | 09:53 AM
fishfryer527's Avatar
Key. Although I remember from MSF they said to use the switch
Old 09-02-2006 | 10:30 AM
eml23's Avatar
+1. Key. Never worry about draining the battery then.
Old 09-02-2006 | 11:52 AM
OldFatGuy's Avatar
I use switch, then key.
For everyone that says key so they don't leave the lights on and drain the battery -- do you leave your key in the bike?
Old 09-02-2006 | 12:01 PM
So you use two devices to do the same as the one the factory designed to do the job?
I guess I don't get that.
If you want the extra safety, then put the kick down with the bike in gear. That shuts off the motor, then you can use the switch to be sure it's off, then finally the key to make sure it's really off.
Seriously. Read the owners manual.
The only thing the kill switch is really good for is screwing with your buddies at a stop light.
Quick Reply: turning off youre bike
