Turn Signals in Air Duct
Old 02-03-2009, 01:59 AM
Dominate.'s Avatar
Default Turn Signals in Air Duct
I don't know if anyone has tried this, but do you think it would be okay to try to put some home made turn signals inside the air ducts in the upper cowl right under the headlights? I was thinking maybe I could buy some amber LEDs and stick some in there.
Old 02-03-2009, 02:00 AM
Aken's Avatar
July 2008 ROTM
Sure, been done before. Go nuts.
Old 02-03-2009, 02:28 PM
alloutf4i's Avatar
That is a good idea. I may try that just for the look of it.
Old 02-03-2009, 03:49 PM
Rocfrog's Avatar
Search and you'll find several...
Here's a few pics of mine!
Nick
Old 02-03-2009, 03:53 PM
ryan_a's Avatar
hey rocfrog can you give me the step by step process on setting that up on the bike.. that actually looks cool. thanks bro....
Old 02-03-2009, 04:02 PM
Rocfrog's Avatar
Not much to it actually...
I just got two small pieces of aluminum and cut them to size and then drilled out the four holes for the 5mm leds and counter sunk the holes one for looks and two so the light wasn't directional because the leds are flush with front of the piece of aluminum. Then I wired in the LED's in series. Then I poprievted them to the vents and then wired them into the blinkers.
Now If I get some more time I can do a full how-to and put it up in the how to section, but I wouldn't hold your breath. So if you have any other questions just ask!
Nick
Old 02-03-2009, 04:28 PM
whiteflash's Avatar
Doesn't sound too hard. It gives me some ideas for some new turn led light schemes...
Old 02-03-2009, 11:06 PM
axsys's Avatar
Old 02-04-2009, 10:37 AM
RojerLockless's Avatar
They are cool but no one will ever see them unless you are behind them, but every time your turning in an intersection or anything like that forget it. IMO if you did this i'd leave some flushmounts or something on the side of your bike too.
Old 02-04-2009, 01:59 PM
Rocfrog's Avatar
They are meant to be in addition to your flush mounts. The problem with flush mounts is they don't project the light forward very well. So this helps. But there not mean to replace you side blinkers....
Nick
Quick Reply: Turn Signals in Air Duct
