turn signal wiring question
so i have a 2001 honda f4i, i recently put some flush mount turn signals in. the only way i could get the to work was wiring the green wire with the positive and the ground to the ground. well, i thought everything was all said and done but now my speedometer dont work and i have no tach, any body run in to this? need some help please
It's possible you blew a fuse. The green wire(s) are ground (negative). Then you have a running light wire and turn signal wire (both positive). I believe the solid colored one (either blue or orange) is the running light and the striped one is the turn signal.
Did the flush mounts you bought come with 3 wires? True, green is always ground on your F4i. You could start a fire wiring them up incorrectly, although thats what fuses are for. If you can afford to buy a manual get a Clymer, they have nice wiring diagrams in the back. You should have a positive, negative (ground) and probably a switch leg. My bike and manual are miles away otherwise I'd check. Keep your relays and relay wires intact for this.
i just fixed it, the wires were crossed. they look amazaing , so much better than oem
Originally Posted by goodsra
(Post 791509)
