Turn sig problem
Turn sig problem
I bought the bike w/ rear integrated turn signals. Either way i hit the signal the side that has the switch on blinks slightly faster than the other, but they both blink none the less. Anyone incounter this problem? I really don't know anything about electrical....
Thanks,
Rob.
Thanks,
Rob.
RE: Turn sig problem
The more things you wrap together, the better the chance of something comin loose. You are correct about "common ground". I was just inquiring on the amount of wires linked together, something along the lines of hookin up a pig tail on a truck for a trailer. If you don't split it up right, they don't work right i.e. both lights blink when turn signal is on, but work OK when just on brake.
dewthedoo05
09-04-2007 09:32 PM
