Tracing fuel pump
Old 03-20-2021, 05:39 PM
Pvtanderson31b's Avatar
Default Tracing fuel pump
2002 f4i. Got the fuel pump working if I jump the pump. Not getting power to the pump though.
Ignition tested and is at 8.9v
BAS bypassed no luck
Kickstand bypassed no luck
Engine stop relay working
Fuel pump relay not clicking
Tested for power at relay, none. Tested Brown/Black off ECU no voltage.
Could this be an killswitch issue or ECM?
Thanks in advance
Old 03-20-2021, 05:59 PM
Also, if its the ecu. Is there a way to just bypass if? Such as run the fuel pump to a switch
Old 03-21-2021, 10:50 AM
I would start with the kill switch as it is a component that is know to fail.
Old 03-21-2021, 10:53 AM
74demon's Avatar
Check your grounds. I think the one for the fuel relays is on the front od the frame by the forks.
tbow
05-16-2012 12:22 PM
Jim Hou
11-22-2011 07:16 AM
blakesgst
10-01-2009 11:57 AM
gaillarry
09-19-2008 01:49 AM
frankinbarnes
03-20-2007 11:56 AM
Quick Reply: Tracing fuel pump
