Took my tank off & lost the fuel rail nut what size is it?
When i removed my fuel tank i just removed the fitting down by the fuel rail ( belived its called a banjo fitting?) looks like a cars brake line and i lost the brass nut, more like the bike ate it. Anyway was wondering if anyone knew were too get one what size and thread it is is one of the last pieces too get my bike together
i belive the nut on the right is what im missing its on the right side of the bike im lazy and really dont want to have too remove the fuelrail just too find this nut. thxs everyone
don't settle with the bike ate it, that's not good to anyone on the road. also do you have the washer? im not 100% but i think it uses a crush washer or 2.
how would you like that sweet turn you make, then hit a 1 inch nut on the rear wheel and you lowside or worse?
if its still in there its a good idea to find it, it will show up.
it shouldn't have went far you probably set it down somewhere quick when you started pouring gas everywhere.... trace some steps
if anything it is probably hidden under your vac lines...
but if you can't find it here is a site with good break down it parts and i have had good luck with shipping andprocessing time..
Honda Motorcycle Parts, ATV, PWC Lowest Price Guarantee
give it a try
give it a try
knight202
08-11-2012 08:01 AM
