Tire Pressure
Quick question, what is the tire pressure most of you keep in your tires?
RE: Tire Pressure
It depends on the rider. Standard is 36 & 42...2lbs below isn't that bad. But when it's warmer, the tire expands and etc. so it's your own call, but nothing really under 32 for each
RE: Tire Pressure
around 33-34
RE: Tire Pressure
25 on the back.
RE: Tire Pressure
25?? that sounds alittle low, probably good if your at a drag strip but i would guess that might take away from handling, mine is always at 34, all around.
RE: Tire Pressure
25 is good if you want to do slow HIGH wheelies. This guy must be a stunter.
We should meet up sometime. Daniel Thompson |
RE: Tire Pressure
38-40 when it's warm out 34-36 when cold.
