tips for removing oil filter
#21
I've had to use a screwdriver thru the filter once from the previous owner, check out my post from another thread with the same issue.
https://cbrforum.com/forum/showthrea...665#post707665
#22
#23
#24
#25
#26
#27
pull off left leg fairing. allen key and screwdriver is all it takes. the exhaust is split between the 2 runners with enough room for the oil filter to be removed.
if you cant take off the filter with your hand then use a tool. but for the near future only put your filter on hand tight and remove it by hand, you shouldnt need a tool or ur just weak (no offence), then after. dont forget to lube up the rubber gasket on the filter.
#30
did my 1st oil change on the bike. oil pan i bought was way too high so i had to go get a lower one. the filter wouldnt budge i got a pretty strong arm but previous owner may have put it on real tight. had to get a wrench and it came off easily. did the foil trick and had not 1 drop get on the headers. i may have filled it little past 3.5 qts though. i had to squat down while holding the bike with 1 hand straight and look real quick at the level.
