tips to get off stuck oil filter?
RE: tips to get off stuck oil filter?
After you are able to remove the oil filter, go buy a K&N filter and install those. They are much easier to install/remove thanks to a 17mm nut on them.
I used a oil filter plier, dented the sh**t out of the oil filter, but managed to get it out and then installed the K&N.
ORIGINAL: TBFGhost
Get yourself one of these....you might be able to find it at sears, if not a one of your local auto parts stores should have it.
http://www.sjdiscounttools.com/lis63600.html
It will do the job, also, just make sure you put the oil filter back on hand tight, not with the wrench.
ORIGINAL: bluej511
I paid 5$ for mine at autozone.
ORIGINAL: bluej511
nope mine isnt welded it has 2 pins that the whole assembly spins around
http://www.autozone.com/R,NONAPP5221...ductDetail.htm
Or if your really **** and need to torque things down just buy the cup thing.
