Throttle Problema
Ive had a couple of problems with my bike but I read through and found out one which was the FPR which was common and bought another one and replaced it and drove it for about 80 mile and it doesn't smell like gas anymore. But I still have a problem with the throttle response it doesn't pick up like its suppose to and feels like its struggling to get to 10 RPM when before I could get pass there with no problems. Any thoughts on what it could be?
is your air filter clean? what grade gas are you using and are your cables adjusted right? (throttle cables?)
yes the air filter is clean just got a full service not to long ago and all of the cables are tight and using 87 gas...ive had the bike for a little over two years now did some searching and found out that it might be the spark plugs a guy had a similar problem and also with the FPR going out it causes other things to fail so Im going to try and check the spark plugs first because all cylinders might not be working
